destrekor
BLUF/TDLR: 94 degree C !!! HAAALP!
I've had two of these Lightning 290X cards for a few years now, and used to run in Crossfire, which necessitated having the top card modded with a Corsair H75 AIO cooler. Everything ran great for a long time, even overclocked. Lately, I've been having some issues. I removed the bottom card (which has a stock cooler). Now, games like Battlefield 4, Battlefield 1, and now BF V, have just never played nice with Crossfire on my system, and a buddy had similar issues and gave up on multi-GPU and AMD entirely.
But that aside, even running with a single card, what I've noticed now is that the temperature is just not right at all. I had went so long without playing games that I completely forgot just about everything about my original setup! lol I've been trying to get back into it and have just become incredibly frustrated.
What I've come to realize is that these temps were never this insane. They were getting toasty and obnoxiously loud when there were two cards in play and the top card was trying to have a literal meltdown, but the top card never remotely approached the 90s.
What's been happening is essentially the card is throttling, using Afterburner I can watch the frequencies stay at the max setting for awhile and then start randomly fluttering lower while temperature is pegged at 94C.
What I've looked into:
The pump RPM has been maintaining the usual ~1500 RPM and both fans on the radiator are running, controlled by the card/afterburner (pump/block is plugged into a PWR FAN header on mobo.
Wires are all connected as they should be, and have visibly confirmed everything is running, and using touch confirmed the pump seems to be running. And as stated earlier I have confirmed that pump RPMs seem to be reporting correctly -- I at first thought maybe something went wrong with an update or BIOS reset or something and the pump was running at a lower speed than it should be, but I can't find evidence that is the case, as both the BIOS and software readings all suggest the pump is running at max.
If it matters: these cards were utilized fairly heavily in some GPU crypto mining, mainly XMR and ETH. I ran them typically 24/7 for the better part of a year, starting to taper down when the house got way too hot in the summer (ancient central AC needs upgraded, badly).
I would say nothing was improperly installed/mounted at the time, or for years. I maintained temp control while mining, and had plenty of time gaming, pushing everything I could out of the cards, without any issue. But now throttling seems to be the norm and that's killing the gaming experience.
Could it be as simple as needing new thermal paste? Idle temp right now is at ~40C, which based on recollection and some quick search for reviews seems to be normal... I would think idle would be much higher if thermal paste was the issue but I could be wrong.
Could the mining have caused some kind of chip destruction hell that keeps it running rather normally just really hot? That seems the least likely of possible causes.
Does it sound like perhaps the AIO kit has lost water through evaporation? I never saw evidence of prior puddling or other signs of leaks, and nothing else behaves weirdly to suggest anything was shorted. Granted the liquid coolant *should* be non-conductive but I don't know what they use.
