MSI KT7 Turbo ? IDE Problem
cyberdude
27
When I connect HD on ide 1 and cdrom on ide 2 BIOS only recognizes HD but not the cdrom. When I flip the cable (cdrom on ide1 and HD on ide2) everything is recognized fine. But the manual says that HD should always be connected to ide1. Am I taking a performance hit by connecting HD on ide2? I did tried every BISO available for that board.
MSI KT7 Turbo (BIOS 2.6)
Duron 800
256 Ram (PC133 Crucial)
20 Gig HD IBM deskstar
50x CD-Rom
Elsa Geforce2MX
Thanks
steve62
26
I've bever run into this problem with the K7T Turbo myself. You might want to field your question the MSI gang at
amdmb.com
Someone there should be able to help you out.
Regards,
Steve G.
850 Duron/ASII/FOP38
MSI K7T Turbo-R
640MB PC133 (Micron) Ram
2X Quantum Fireball AS 20.5 GB ATA 100 HDD (Raid 1)
MS-StarForce 818 GeForce2 MX 32 MB TV out
2X ATA 100 removable drive drawers
Adaptec AHA-2940 UW Pro (PCI slot 3)
Aopen 16X DVD
AOpen 16X burner
akiraxtc
405
It's a long shot but... is your harddrive drive configured for cable select on its jumper?
Consider this scenario: IDE hdd on cable select on cable port 1, CDROM on master on port 2. I think the hdd will not be detected because it's set by the cable on master because its on port 1 on the cable. On the other hand, if you put the hdd (cable select mode) on port 2, and CDRom (Master) on port 1, then everything should work just fine. CDRom would be master device and HDD would be slave. Is that the case with your problem?
DieselMan
2,270
Try to solve the problem if it bothers your conscience, but honestly, I've seen computers configured with the dvd-rom on the primary, and hdd on the secondary, and performance was identical. ;)
