Well I posted about this twice over a 3 month period in the main one, but I realized I should post in the motherboard section instead 😀. Well I have had this motherboard since probably December and it was flawless up until now. Over the past 2 months, it started having troubles with the USB ports. No matter which one I plugged my Logitech Dual Optical mouseman into, the device would stop working. The light to the mouse would still be on, and the laser on...but the mouse was inoperable. I don't think any USB devices worked regardless of that they had power. So I figured it was a software problem. Right? Well, I don't know. I bought a new Seagate HDD and wiped out my drives (backing up mp3s n stuff of course) and reinstalled Windows XP Pro. It still did this, so I switched to my backup mouse, the MS IntelliMouse Explorer 3.0a. It didn't do it for a while, but then it started doing that again with a totally different mouse.
I then realized that USB detection in any linux distribution I would test, it took a LONG time to do. Longer than it ever should...and sometimes, the USB detection would completely hang the installation. I do a lot of work with USB ports so it is essential to solve this problem by summer's end. Does this sound like my USB ports became defective over time somehow? If so, should I try and get my money back and get an nForce2 board instead? I'm not sure what path I should take, or if I should get it exchanged for a different MSI KT400-based board (if possible).
