MSI KT4 Ultra-FISR (KT400) Review!
Mem
21,476
13
Over@FiringSquad
If you?re not looking for a motherboard with everything but the kitchen sink thrown in, we?ve seen KT4 Ultra variants without the Gigabit LAN and Serial ATA for prices just under $100, but with prices on the loaded KT4 Ultra-FISR we tested hovering as low as roughly $120, we see no reason why most consumers shouldn?t spend the extra $20 or so and get the board that is loaded with more features.
Insane3D
19,446
Couple of things I noticed...
First, it looks like MSI decided people don't need to use a nice HSF like the Alpha or Swiftech since they no longer have the four mounting holes around the CPU socket. Second, it appears they are using a bi-phase power design over the much more common tri phase design on most other boards.
DieHardware
1,706
I would buy the bi-phase design using quality components over a tri-phase design using cheaper parts.
LostHiWay
1,544
The things I don't like about it is that it uses a Promise chip for the RAID. I'd rather have Highpoint.
Next thing is that you can only increase the CPU voltage to 1.75v :(
Insane3D
19,446
Yeah, and I would take a high quality tri-phase over a cheaper tri-phase or the best bi-phase in the world..:p
Mem
21,476
13
Now guys calm down ;),in the end as long as the board is very stable it does not matter,I`m using a single phase board (MSI K7T PRO) and 3 phase board(Epox 8KHA+) and both are rock stable.I`m sure MSI would make sure power stability etc is fine.
Insane3D
19,446
Never said it wasn't stable...just think it's too bad MSI chose the cheaper bi-phase route on such a high-end board... I don't make comments about boards stability that I haven't used. Don't you go putting words in my mouth now Mem...;)
The power supply components are not much of an issue at stock speeds anyway...it comes into play more when overclocking when a steady, clean stream of power to the CPU and board components really matters most. :)
Mem
21,476
13
MSI are not known for making OC boards,we leave that to brands that make good OC BOARDS like Epox and Abit ;).Btw Pete I didn`t say you said it was not stable,just that MSI would not use 2 phase if they didn`t think it wouldn`t be up to it ;).
