My MSI K8T Neo2-F is having a few problems. Specifically, when I put anything into the second two mem-slots (the purple ones visible here), it won't POST. It powers on, but never puts out any video output.
About the memory itself, the only difference between the first two sticks and the second two sticks is the CAS latency (the first two are 2.5, the second two are 3) and brand. All four sticks are DDR400 double-sided 512MB sticks.
I have several ideas as to what the problem might be, but I really would like some feedback/help.
Firstly, the BIOS Agent reports that I already have 2GB installed, when I only have 1GB in at the moment. The other two sticks are sitting right beside me. However, AIDA32 correctly reports only 1GB of memory. Why this would be, I have no idea.
My other hunch is in relavence to the 'recommended memory combination list' displayed in the aforementioned msi.com URL - it implies that when all four slots are filled with double-sided memory, the maximum speed is DDR333, as opposed to DDR400. However, I would think that this would only down-throttle memory speeds to DDR333 speeds, instead of causing boot issues.
Any ideas?
EDIT: For the record, I can't boot ANYTHING in the purple slots - not even the old RAM that I know works. I've tried using the DIMM1 and DIMM3 slots, as well as the DIMM2 and DIMM4 slots - the same issue persists. However, if I use DIMM3 and DIMM4, it boots fine. I'm starting to think that I've just got a bad slot.
Any ideas?
