MSI K8N SLI Boot problem
Merlin
I bought this board and have not had many problems with it except that it hangs up on start up every time after it completes the post but before the windows splash screen. The video does not go out, it just hangs. If you then hit the reset button, it POSTs again and then comes up with the windows was not shut down properly screen, if you hit start windows normally everything works fine. Anyone else have this problem or know a fix? I have the latest bios.
I had a similar issue with my Neo3 board. If I installed the drivers out of order, the system would lock up when windows booted.
After a lot of trial and error I found this order was best:
1. One-Touch Setup (MOBO Drivers)
2. Video card drivers
3. GART drivers
4. Any remaining drivers
Hi, I have the same problem.
I solved it unplugging my USB mouse and using an adaptor for ps/2.
Don't ask me how I got to this...
