MSI K8N Neo4 Platinum Ultra non-sli USB POST problem
swimscubasteve
523
Windows is installed and the comp. boots fine without ANY USB devices plugged in. When I plug any USB device in before booting, it hangs at POST.
If I plug the USB device in after its in windows, it works fine.
I've tried everything, looked everywhere but I just can't figure it out.
Please help if you can. I heard that this is one of the best forums out there and I try to solve things on my own but I've just about given up.
Specs:
Athlon 64 3000+ Winchester
ATI x600 AIW
Corsair valueselect pc3200 2x512 dual channel
WD Caviar SE sata HD
Thermaltake Silent Purepower tt-420AD 420w
Dyloot
302
What PSU are you using? It very well may be a power issue. You have a powered USB hub that you can use when you boot?
Dyloot
Dyloot
302
Well, that should be good enough. What USB device are you plugging in? You have, or know someone with, a powered USB hub that you could plug in and try?
Did the users on the MSI forums get any answers?
Dyloot
swimscubasteve
523
I FIGURED IT OUT!!!
To all those who are having problems with this:
UNPLUG YOUR FRONT USB HEADERS FROM THE MOBO!
Some sort of pinout problem.
read here
So how do I get the front panels working? Could someone help with this?
chrisralston
64
That is something that I noticed to. My rear USBs have items plugged in and no problem booting. I once had my iPod Shuffle plugged into the front port of the case, and no boot up. I think that I have been able to boot with a game pad pluuged in, so maybe it is only when the device has data in it?
us3rnotfound
5,334
I had this problem too. But what I did to fix it was go into CMOS and disable the "enable usb keyboard/usb support," and my usb keyboard still works, and it no longer hangs at bootup :confused:
I think this is the last board I buy from MSI, they pretty much suck these days. I should have just stuck with ASUS, which in all my years of using a computer have had 0 problems.
