MSI K8N Neo4 bios problem
darkcyber
I ran Tune Up Utilities 2007 on my pc...I've run a lot of the features in there with no problems. I ran the one about checking the hard drives. It came up and said it found errors on my C: drive, which is my 35 gig Raptor. It said it needed to reboot to fix the problems. I rebooted it and then it starting running like the chkdsk thing and then it rebooted after it finished that. After it did, all my pc will do is hang on the bios screen where it shows the cpu and ram amount. It shows I can press del to enter the setup, but nothing happens. It just sits on this screen. I've cleared the cmos, removed the battery...etc. but still nothing.
Any suggestions here?
Thanks!
