imported_Candyman
I recently purchased the MSI K8N Neo2 Platinum with Athlon64 3500+(90nm). I already had a Antec Sonata case w/ True380S PSU. The install went smooth and it managed to boot on first try and allowed me to install WXP. I finished setting up XP that night and went to bed. The next day I went to go turn it on and when I pressed the power button the power led lit-up for a second and went out. I took side cover off case and observed what was happening when I pressed the power button. The fans would start to spin up and the led's on memory would flash--then it would just die. I thought my power supply had gone bad, so I swapped it with a 550w Vantec stealth PSU I have in my server. As I expected, everything fired right up. I then got online and ordered a new PSU from zipzoomfly.com. I decided on a 480w Antec Neo PSU. Well, today when I got home from work I installed the new PSU and to my disappointed it did the same thing the other Antec PSU did. This leads me to believe their is a issue with this board and Antec power supplies. Has anyone else had similar problems with this board and Antec PSU? And what 939 board would you recommended as an alternative?
Thank you!
--Adam
Thank you!
--Adam
