MSI K8N Neo2 mobo and ATA speed issues
MainframeGuy
38
I have just built a nice new AMD64 3500 system and there is one problem left that I am pretty sure is hitting performace really hard.
Although I have one SATA drive at present my system is installed on a partition on the Master IDE drive (I have two IDE drives). Anyway when I access the IDE driver from Device Manager and check the speed the master is running UDMA 5 (=100) and the slave is running UDMA2 !!!
Correct me if I am wrong but aren't they all slowed to the lowest speed aren't they? It sure looks like it when I use hibernate mode and come out of hibernate it is slower than my Athlon 3000+!
I have ordered a couple of spare IDE 80 cables to try changing that, but can anyone else help or offer any other advice.....
thanks guys
Cheetah8799
4,508
I was just going to suggest you try replacing the IDE cables, especially if they are crimped or bent a lot.
MainframeGuy
38
not crimped or bent - but they came with the MSI mobo and they are the type which I think immitate narrow ones by having heat sink on their lengths and just rolling up standard IDE cable (cannot be good for the signal I guess?) - anyway like I said replacements on order to try - thanks.
MainframeGuy
38
The newer IDE ATA drive is a Samsung Spinpoint P SP1614N 160GB ATA-133 8MB Cache and the older is a Seagate Barracuda I forget the model, but I know it is 80GB and 7200 rpm with ATA133 (bought a 2 or three years back, same price as spinpoint now).
So, they should both be UDMA6 capable SFAIK
MainframeGuy
38
OK not an answer as such, more an update of sorts --- I just took an image of my windows partition and moved it to my SATA single drive.....
A lateral thinking solution to say the least ! Also a shed load of work (I have learnt a few tricks there - like even single drive has to be RAIDed for SATA plus only SATA 3/4 on my mobo seem good for my SATA drive plus you MUST unplug IDE to format and install XP to SATA.....
Aside from that :eek: it was easy as pie... hehe
