First here are my specs:
MSI K8N Neo Platinum nForce 3 Bios 1.9
AMD Athlon 64 3000+ Newcastle (stock speed not overclocked)
Corsair CMX512-3200C2 Ram (2 for 1GB total)
MSI ATI 9800 Pro Video Card
Antec TruePower 380 Power Supply (came with Sonata case)
Audigy 2 ZS Gamer
Windows XP Pro SP2
First I plan on buying a new PC in the next month or two and would like this one to work properly so I can sell it.
I built this PC about 3 years ago. Everything ran fine for a year or so. Then every once in a while the PC will instantly shut down with a message that states that my video card does not have the power cable attached. Usually I just hit the power button and it would boot back up and run fine for months. That is the first strange problem.
The second strange problem started about 2 months ago. The PC would just freeze and I would have to hard reboot. And then it would take like 10+ mins to boot up. It always seemed to hang during the memory check part of the boot. I tried to use the LED bracket that came with the motherboard to troubleshoot but it seems to not work correctly.
So I decided to check the ram. At first I had the ram in Slot 1 & 2. So I moved to Slot 2 & 3. Same thing. Then I decided to run just 1 DIMM in slot 1...bingo booted up like normal. I tried the other DIMM in slot 1 and it worked as well. I then put only 1 DIMM in slot 2 and ran Memtest...tons of errors. I then moved that DIMM to slot 3 and ran Memtest...it wouldn't even run. But with the DIMM in slot 1 Memtest runs fine.
So I have been running my PC on 1 DIMM/Slot 1 (512 MB ram). But now my computer makes a random beep every once in a while. I don't know if it is from my power supply, motherboard, etc... Plus the PC is just slow with only 512 ram.
I thought that my motherboard had two bad DIMM slots but now I think my power supply is going bad? Any ideas? I really need to fix this so I can sell it.
Thanks for you help.
P.S. - I don't have any extra parts around so it is hard for me to swap power supplies, motherboards, etc...
Audigy 2 ZS Gamer
Windows XP Pro SP2
