imported_Roy
Hi I have a MSI K8N NEo 2 platinum MB with an Athlon 64 3000 + venice Core .
When I bought this System 1 month Ago , After installing It I had some problems to Turn the PC on, the Problem with the BLACK Screen , So I changed some Rams And everything worked Fine. But from time to time I have some FREEZE ( I have to restart in order to fix it ) and they don't have a certain Pattern, they come Randomly, While Playing Video Games ... Surfing the Net .. sometimes Directly on the Startup of Windows.
It's Not a CPU Temps problems I monitored those and they reach 56-57 under load, So I guess it's a problem related to the MB itself. Any Idea on how to find the Exact problem ?
PS: I have the Bios V 1.5 and this freeze occurs more often when I Plug a USB Stick ( Ipod...) or When i Take out my Sound blasters Plug to put My headphones. So In general when i Stick something in the MB ... I dunno if that Helps.
Thank you
Thank you
