Hi Guys,
Two things about the MSI K7T Turbo board and Durons:
1. The 2.4 shipping bios does NOT initialize the Promise Raid controller bios if you
have some brands of TNT2 (Leadtek Winfast2 Ultra) or the Geforce 256
(Hercules 256 DDR-DVI )cards..maybe others
You don't even see the Promise screen at all.
Solution: flash to the latest beta (b16 I think) and you're good to
go...MSI Techs were not aware of this, but I verified it with different AGP
cards.
2. I was having trouble getting my unlocked Duron 600 which I usually run
at 101 fsb x 10 = 1010 Mhz. to come up in 133 fsb. It seems that if you
don't get a successful boot after changing some multiplier/voltage/bus
setting in the K7T Turbo Bios (either v2.4 or Beta b16) the system will
reset to the DEFAULT multiplier on the Duron chip. For me it kept resetting
to 6 x 133 = 800 Mhz.
MSI should address this in a bios update so that you are'nt forced back to
the chips Default multiplier (at least fix the Overclocking bios's to not
act that way).
Solution: I had to set the 100/133 jumper on Motherboard to 100 Mhz. Then
go in and set my multiplier to what I wanted it to be when it would
eventually be set to 133 fsb.
What I mean is that I had to set it for 7.5 x 100 (which I knew it could
handle) to get a clean boot at 100 fsb.....but anticipating eventually doing
7.5 x 133. Set my voltage at this time also to what I knew chip needed at 1
Ghz speed.
Then I would do F10 and save and exit bios screen but right away KILL the
power strip........then bleed any remaining power from the PC by depressing
the power switch on PC even though power strip was off. THIS IS CRITICAL.
Next I turn on the PC and check for (750 Mhz) 7.5 x 100......if I don't
immediately see confirmation of my desired 7.5 multiplier (which I'll need
for proper speed at 133 fsb) I'll kill and bleed the PC again till I boot
and see that magic number.
I then shut off and bleed the PC again, but now I change my jumper to 133
fsb and reboot........again, if I don't see the proper speed at post (997
Mhz 133 x 7.5) I'll kill and bleed the PC again and usually that is all it
takes.
Once you have forced your multiplier to the desired setting for your chip,
you should not have to go thru this process again (or at least until your
next flash).
BTW.....I am writing this post with my K7T Turbo proudly driving my little
Duron at 1020 Mhz (136 FSB x 7.5).
I hope above info helps some people out.....it took alot of reboots to see
any kinda pattern.
Thx,
Jon
cards.
act that way).
Ghz speed.
takes.
next flash).
any kinda pattern.
Thx,
Jon
