I did a win2k install on the following system:
K7T Turbo Raid with a 1ghz Athlon @ 1 ghz
256mb crucial sdram
wd 30gb hd
V3 3000 Agp
300W PSU Fortron Sourse
Here are the symptoms that i have encountered. I installed via 4in1 4.32 and rebooted. Everything went fine. I started installing the sound driver, but the message poped at me saying: Via Ac97 codec chipset is disabled in a bios, please enable in the bios first and then install the drivers. I said ok and then rebooted, got into bios and checked the audio. Everything that was needed to be enabled was already enabled. I checked device manager and found no unknown devices that were there. Everytime i try to install the audio drivers it doesn't work. I don't know why. Keeps giving the same message.
Please respond, I will appreciate any feedback.
256mb crucial sdram
wd 30gb hd
V3 3000 Agp
