I bought MSI K7T Pro2-A, Tbird 750MHz and Taisol CEK733092. They came to my home with CPU and fan installed. I put them into my new PC without any problem. After I booted up my PC, I noticed that CPU voltage is 1.84V(FuzzyLogic3 indicated this). Is this normal? I also noticed that in BIOS I can?ft choose CPU clock ratio below x10(Minimum is x10.). I think this is a bit different from what I know, but is this normal, too? Then, using L1 bridge pencil trick, I was able to overclock the chip to 999MHz by choosing FSB 95MHz(through FuzzyLogic3) and x10 CPU clock ratio with default CPU voltage. Isn?ft this weird? What do you think?
