I know this type question has been asked in the past, but despite searching, I remain confused.
I puchased an EIDE Plextor 12/10/32 CD-RW to add to my system and am unsure what will be the best configuration.
My current set-up:
MSI K7T Pro
Duron 650 o/c to 700
128 PC133 RAM
Hercules GeForce 2 MX
Win 98 SE
IDE channel 1: Maxtor 7200 rpm 30 GB HD 66
IDE channel 2: Pioneer 10 X DVD-ROM (master)
Iomega Zip drive (slave)
I currently have DMA enabled on my Pioneer DVD, but am unable to use DMA on the Iomega zip drive.
Since I have no immediate plans to add another HDD to channel 1, is there a way to add the CD-RW without compromising performance?
My thought was to do the following:
IDE 1: Maxtor (master)
DVD-ROM (slave)
IDE 2: Plextor (master)
Zip (slave)
The confusion that seems to exist among the stuff I've read, is whether or not adding anything to the IDE channel 1 will cause a hit on HDD performance.
Would it be better to just install a separate controller board? If so, I would appreciate any specific recommendations or insight re: this particular MB.
If I do add a separate controller board, do I need to reformat and reinstall?
Thanks for your patience in what I'm sure is a repeat question.
My current set-up:
MSI K7T Pro
128 PC133 RAM
Win 98 SE
DVD-ROM (slave)
Zip (slave)
