MSI K7T PRO 2A- - sudden boot, when switch of the power cord at the wall is switched
CK
27
hi,
my pc suddenly boot up when i switch on the plug on the wall, not the switch on the pc, it boots up automatically, then shutdown inwithin 2 second
is it the mobo problem or can it be the case problem ?
pls help
btw, the sound blaster thing in the bios, do i enable it ?
thanks
MSI PRO2A
TBird 800mhz
128 mb ram
20gb maxtor hdd ata 100
barlav
340
This is normal I believe. Mine did same thing. The board has an auto power on feature. Look in the board's manual as it describes it in there. It should power on for a second or two and then shut off. After that it should work normally.
freefalle6
62
Heres the fix for my kt7 pro a i went into bios and under power management setup then go to state after power failure and set it to "off" reboot and its fixed!!!!!!works great now.
FREEFALL
system: 1.1gb tbird
Msi kt7 pro A
asus v7700 gf2 32mb DDR
128mb pc133 ram
maxor 13.6gb hd
d link Nic
us rob 56k ext modem
40xcd
hp 8100 cdrw
yamaha sound card
300 watt sparkle p/s
holdencommodore
1,061
Doesn't this happen on Switchable cases too?
freefalle6: isn't the MSI board called K7T Pro not KT7?? The KT7 is the Abit board! ;)
