hey guys/gals. is it possible to run a duron 650-800 using only a 200 watt power supply? ive always heard people recommend 300 watt minimum, so guy claims that a 200 watt power supply works fine. what are your thought? thanks for the help.
What really matters is what the combined +5 and +12v wattage is, should be around 150 watts. You are teetering on the edge with a 200, it may work, but it may not. I wouldn't recommend it, when great 300w PS's like the Antec PP303X are so cheap.
