I've posted this problem over at Ars, but haven't gotten any very helpful responses. So I thought, since there's so many K7T fans here, maybe I'd have more luck posting it here.
I've just built the following system:
When all the cards are in, the system will not boot past the FastTrak66 looking for IDE drives. It just hangs with a blinking cursor. If I take either the 3Com or the SB Live! out, the system boots without so much as a hiccup.
Here's what I've tried, all without luck.
- MSI K7T Pro
- Thunderbird 900
- 384 Mb PC-100 RAM
- TEAC Floppy
- Sony CD-ROM (48x)
- Zip-100
- (2x) IBM Deskstar 30Gig Drives (7200rpm, ATA/100)
- FastTrak-66 RAID Card
- 3Com 3C905B Ethernet card
- Matrox G400 (Single Head) 32Mb AGP)
- Creative Soundblaster Live MP3+
- MicroStar 750A Case (w/ 400Watt PS)
- Flashed the BIOS to the latest rev.
- Diabled all onboard ports (COM1, COM2, LPT, USB, IDE1, IDE2, SOUND) individually and all together.
- Set all IRQs to legacy ISA mode (together, individually, and in some combinations)
- Moved all cards into several (though not all possible, since that would amount to more than 700 possibilities) different slot configs.
- Set INT Pin 1-4 Assignments with 16 combinations of IRQs
- Changed the 3C906B with a 3C905C
Has anyone else run into this problem? How did you solve it? I'm not averse to buying a new brand of card, if I know that the new one won't have the same problem (i.e. "card a is better at IRQ sharing than card b, I have this setup and it's working fine."
If you want to see how my IRQs are being assigned with a few different slot configs (not all the ones I tried, but a decent representation), go here: ArsTechnica Original Thread
This system would easily be the best system I've ever worked with (barring servers, of course) if it weren't for the fact that I can't use my SB card! Please help!
