MSI K7N2G power-problem
I just got this new nForce 2 equipped board. I use 4 PC's on a TrendNet KVM switch, so I can use one monitor/mouse/keyboard for 4 PC's. But the K7N2G doesn't seem to like doing that. Most of the time it will simply not find the PS2 mouse upon boot, and if it does it will loose connection to it after a few minutes. No other PC has ever behaved like this on the KVM - I have used 5-6 different motherboards without any problems.
Do you think it could be a problem related to the chipset/motherboard? I have to decide whether I should deliver the board back and put nForce 2 on a "blacklist" of motherboard chipset not to use, or whether I should get it replaced for another board and hope it doesn't have the same problem. The board seems to run without problems when I am not using the KVM.
