I am using the MSI K7N2 Delta ILSR board, with an AOpen H600A case, and when installing the external 6-channel bracket, it will not fit in the slot! The bottom of the bracket hits the mobo components, whatever slot!! has anyone else had this problem? could you check on your boards for me? and MSI, should this be happening - looks like a design fault
i was thinkin of simply cutting off the excess plastic on the bottom, but that has the bottom screw in it and would probably invalidate my warranty
also feel free to email me if you have had this problem
