I've had a MSI K7N2 Delta ILSR for about half a year now, and i've had a few problems, mainly with the CPU. I had a AMD Athlon Model 4 "Thunderbird" A1333AMS3C, which should run at 1333 Mhz with an FSB of 133 Mhz. Me and 3 friends all bought this mobo at the same time from Ebuyer, and when they installed their processors all of them didn't detect the CPU settings properly, and had to be manually set. It all worked fine for them then. When I set my FSB to 133 though, it went from 994 Mhz to 1002 Mhz, instead of 1333. I didn't really care at the time, because I had been planning to get a new processor soon, and didn't really need a high speed one at the time. Now I've gotton a AMD Athlon XP 3200+ though, and it detected it at 1000 Mhz when i put it in. When I set the FSB to 200 Mhz, it went up to 1100 Mhz. This is the second processor that's not running at full speed. Anyone know why it wouldn't be running at full speed? A friend suggested the "FSB/DRAM ratio" setting in the BIOS might have something to do with it, but i don't know what i should change it to, if I should change it at all. it's currently at Auto
Athlon XP 3200+
Sapphire Radeon 9600 Pro Fireblade Retail
MSI K7N2 Delta-ILSR
Onboard Sound
Plextor Premium CD-RW 52/32/52
DVD-ROM 16x
Intel(R) 536EP Modem
Windows XP Pro SP1
Q-TEC PSI 400WP Dual Fan Gold
Cooler Master Jet 7
Athlon XP 3200+
MSI K7N2 Delta-ILSR
Onboard Sound
DVD-ROM 16x
Windows XP Pro SP1
Cooler Master Jet 7
