MSI K7 pro and Tbird 900?
HuntnPeck
225
I just recently picked up a 900 tbird with a gig core. I have an Abit KA7-100 that won't boot with it so I got the k7 pro to run it. Now the fun begins! The tbird gets a hard lock in a few minutes of being on. I even took out the geforce2 and stuck in a pci card but it still locks. With out changing anything I put my classic athlon in and its rock stable. I don't know whats happening.
My system so far:
K7 Pro with 110 clock gen 1.7 bios
SBLive!
Elsa Gladiac
128meg Apacer Infineon ram
Adaptec 19160 scsi pci controller
tried both an antec 303X and pcpower&cooling turbo 300 power supplies
Radarman
203
Sounds like it may be a heat issue with the Thunderbird, thats a classic symptom. Radarman
HuntnPeck
225
I'm using a fresh install of win98se. I have an artic circle on it, but the processor shouldn't hang when running at its normal speed should it? Anyway I gave up today and put my ka7 and classic athlon back in until I can isolate the prob.
On a side note I used a gfd to bring it down to 800 and it still locked up. I even tried 700 on the ka7 and it won't post. Maybe it might be the processor...who knows.
Radarman
203
I agree, it sounds like you may have been unlucky enuff to have picked up a bad processor, can you return it for a replacement ?? That seems your best option now. Radarman
Bakwetu
1,681
I don't know why the k7 pro and the t-bird doesn't work, but the ka7 and the t-bird might be incompatible. The ka7 is based on the kx133 chipset, which sometimes (with lower clocked parts) work with t-birds, but in many cases don't (that's why they released the kt133 chipset).
The ka7 is still one of least incompatible kx133 mobos to use with the t-birds, and there are some bios tweaks that might make the t-bird run, but I don't know exactly which (I have a asus k7v myself). Search the forums or ask at amd zone for that.
HuntnPeck
225
Impact55,
You got me thinking. I switched the fsb to 105 and it locked up quick. I then set it to 95 and I can't crash it now. I raised the multiplier to 10 and its kickin along at 955. Does the K7 Pro recognize 10.5 multiplier because it wont work with the K7OC gfd I have. Anyway, I'm so glad to see it actually working:)
kelesh3
Banned
Oct 31, 2000
727
before you put run it for the first time you have to clear the cmos with the jumper near the battery. the msi k7 pro is looking for a classic athlon. if you clear the cmos, it will accept your thunderbird. i suggest you reformat, flash your bios, clear your cmos, and start fresh.
