M maidos Member Dec 20, 2009 26 1 66 Nov 10, 2014 #1 is this considered normal since the coilwhine occurs when i play medium gpu demanding games i dont think fsb 100 should be considered normal? Last edited: Nov 11, 2014
S Silverforce11 Lifer Feb 19, 2009 10,457 10 76 Nov 10, 2014 #2 Not normal at all since your GPU temps are not high (65C max). Coil whine seems to be a common complaint of many 970s. Looks like AIBs cheap out on components.
M maidos Member Dec 20, 2009 26 1 66 Nov 11, 2014 #3 ic, then its for certain issue with my motherboard then? http://i.imgur.com/BzP4klX.png
9 96Firebird Diamond Member Nov 8, 2010 5,748 345 126 Nov 11, 2014 #4 I think you're reading the graph titles wrong. The titles go with each graph below the titles... Looks like your max FB usage was 50%.
