Question Msi GS65 Stealth Thin Power Limit Throttling
adiktech123
Hi,
I recently bought MSI GS65 Stealth Thin ( i7 9750h + RTX2060)
While playing games or even some heavy tasks. I can see power limit throttling issues
Can anyone suggest me some solution to this?
- thanks
HD7970GHZ
I have the exact same laptop. It is unfortunately a part of the build - it being so damn small and light. Don't be too worried about the thermal throttling, it really isn't THAT big of a deal.
I have the 8750h and the GTX 1060 and I have to downvolt everything and underclock a bit too. I get Intel Extreme Tuning Utility, or throttlestop. Both will do, just don't use them at the same time. Also - use MSI Afterburner to downclock your GPU. a GTX 2060 in a laptop is unreal overkill!
HD.
Reactions: corkyg
