I received my MSI BXMaster mobo a few days ago and I have read over the manual carefully and examined the board to get familiar with all of the jumpers, headers, etc. I came across a thin, tan, wire-like item sticking about 1.5 cm above the mobo next to the CPU slot. The manual calls it a "CPU Temperature Sensor: JSOR1" (follow this link to see a picture: www.lithomedia.net/cputemp.jpg). I believe this sensor is a thermistor, although the manual doesn't use this term.
My concern is that I place this temperature sensor properly when I install the CPU. Is this termistor supposed to slide up through the middle of CPU card so that it is positioned between the CPU ad heatsink? It's so tall that it doesn't look like I have a choice; I'd have to bend it out of the way if it weren't supposed to slide up the middle of the CPU card.
Thanks for your help.
MSI BXMaster
700/100 PIII
15 GB IBM 75GXP
256 MB Crucial ECC PC100
Plextor 8/4/32 CD-RW
Acer 50X CD-ROM
NT Server 4/SBS 4.5
Fong Kai 320W Black Case
MSI BXMaster
700/100 PIII
15 GB IBM 75GXP
Acer 50X CD-ROM
NT Server 4/SBS 4.5
