MSI ah68 Grenade - Compatible PCI Wireless Card?
jt0195
Hello,
I can't seem to determine the voltage of the PCI slot on the msi ah68 grenade. I need to use the regular PCI slot, as my graphics card (which is in the PCIe 3.0 x16 slot) covers the smaller PCI slot (the 2.0 slot, I believe?).
I'm trying to find a compatible PCI wireless card (in terms of voltage and bits). Below is a link to reference the motherboard. Any help in identifying a compatible card would be awesome!
Thank you very much!
Motherboard:
https://us.msi.com/Motherboard/A68HM-GRENADE.html#hero-overview
Insert_Nickname
4,971
1,695
I'd advise looking for a USB3 wifi adaptor instead. All PCI adaptors I've seen use extremely outdated chipsets (no 802.11ac f.x.).
PCI wise, anything that fits in the slot should work. Luckily there is no need to fiddle with IRQs today.
Welcome to the forums.
