I bought two of these boards, originally motivated to have absolutley no Via anywhere on my my motherboard. Though, I must say my old Epox 8K7A with a Via southbridge was on of the most stable, compatible motherboards I have ever used. Sad to say when I removed it from my case I broke off the I/O voltage mod and messed a voltage regulator.... Dead! Anyhow the MSI 745 Ultra boards are picky as hell, how ironic. I tried three different sound cards and couldn't get any of them to work properly, had to use onboard sound. I couldn't get a Logitech Extreme 3D Digital or a Top Gun Fox 2 Pro to work either, although my ancient Microsoft Sidewinder 3D Pro works fine. The bios setting for cas 2 won't allow me to boot any of three different sticks of Ram at anything above 133MHz although they all ran Cas 2 160MHz on my 8K7A, one of them being a Samsung original PC2700. I had to reformat twice to get Internet Connection Sharing to work properly.
I have both boards running nicely now, one at 143MHz (memory limited) and one at 171MHz. They are stable and fast if you can get everything working, but I cringe at the thought of changing components. I switched video cards and came up with a IRQ mess and had to reformat again. The 761 chipset allowed me to change anything anytime I wanted and worked perfectly. I don't know if I should blame MSI or the 745 chipset for this crap, but it is a lesson learned for me. If it ain't broke, don't fix it! That's my motto and anyone considering this motherboard beware.
