MSI 645 Max Voltage
phamtastik
711
Whats the max core voltage on this?
I haven't gotten my 1.8A cpu yet... but after reading more information I am leaning towards the EPox Sis645 chipset board.
phamtastik
711
Its going back to the store....
I would probably keep it if I had normal air cooling, but I have a vapochill case so I want the extra juice to the cpu.
THanks for the info though
mschell
If you do the standard VID mod, the board can supply 1.8v. You can short other CPU pins to allow 2.0v+ if you feel the need.
The MSI 645 Ultra is a no frills low cost motherboard that happens to be a stable, good performing board as well. As long as you are spending the $$ on a vapor chill setup you might as well spend a bit more to get a board with more overclocking tweaks available in the BIOS but as far as I know, no Northwood board allows more than 1.8v using the BIOS.
