MSI 6163Pro - problems at AGP bus at 100 FSB
tde
52
Hi,
I run a system with MSI 6163Pro mobo/P3-700(fcpga)/I will slotket 2 + ATI AIW 128 (AGP).
BIOS ? W6163MJ V3.10.
It seems that AGP bus keeps 1:1 ratio at 100 Mhz FSB (Reading from Sysopt Sandra 2001.0.7.10 + gives me a warning about this issue).
While systems runs Office applications there is no problem, but when I run 3D games the system get looked quickly.
How can I enable the 2:3 FSB/AGP ratio.
I should note that the FSB jumpers on the Slotket are set to 66MHz and real FSB is set on BIOS.
I had the same problem while running a Celery 300A@450. It would only do 95MHz Max on 3D games.
Should I set the jumpers in a different manner? All other freqs are ok and are changed automatically (PCI, ISA etc)
Thanks
Bartman39
Elite Member | For Sale/Trade
Jul 4, 2000
8,867
51
Yes set the jumpers on the slotket for 100fsb also their are 2 jumpers below the slot on the board itself these to need to be set (see the manual for this also). This should take care of your AGP problem... ;)
