MS/Works file conversion
NJLOAD
582
A friend at work saved some MS/Works files on a floppy, I need to open these files to print the information but don't have MS/Works. Is there a file viewer around that will open these files so I can print them? BTW, excel MS/works 2.0 file format won't open them, I already tried. I don't know what version he used and he no longer has the program on his system because of a format and restore of his HD.
Thanks
Bglad
1,571
Office will open them.
When you try the first time, it will say unrecognized file or something, tell you it can open them if you install a plugin and ask if you want to install the plugin now. Just say yes. It will need your Office dics.
