My 5 GHz Wi-Fi access point reliably provides up to ~480 Mb/s on all other devices. However, my MS Surface Pro 3 only achieves a maximum download speed of 280 Mb/s (Usually ~220 Mb/s). Disabling the Surface Pro 3 internal Wi-Fi adapter and using an external USB Wi-Fi adapter gets the same results. Also, the Surface Pro 3 achieves the expected up to ~480Mb/s if Ethernet hard wired. I would appreciate some advice for troubleshooting as I cannot find a problem and have even followed advice to reset/release/renew/flushdns netsh & various ipconfig parameters. The Surface Pro 3 is specified at 433 Mb/s on 5 GHz . Also, the Wi-Fi signal is very strong, and other devices achieve these speeds in the same location.
