MS SQL Server Question - Script to run on DB to output Create script for tables
TechBoyJK
16,699
60
Is there a command you can run on a DB in Microsoft SQL Server 2008 that will output 'create table' scripts for every table in the DB? I'd want it to include all create stuff too.. like indexes, keys, etc. I'd also like it to output users and their roles on the DB.
KLin
30,950
1,076
1. Right Click the database in SQL management studio in the object explorer window
2. click tasks, then generate scripts
3. Wizard will walk you through allowing you script out whatever objects you want created
4. ...
5. PROFIT
ForumMaster
7,792
continuing on KLin's reply, i don't use sql server. i'm an oracle guy, but two seconds of googling brought me to this page.
good luck.
