Originally posted by: Wuzup101
It's normal. If you were to look at it laying on a glass surface (where you could see it through the table), you would see that the light actually does go out... but when you pick it up it goes on as soon as it detects movement. It's always on, that's just how it is.
I have one too... wonderful things aren't they... I love mine!
I think you're confused. He's talking about after his entire computer shuts down, not when the mouse goes idle, in which case the LED dims but does not go off.
This is NOT NORMAL (Incidentally, I used to have keyboard that used to have the NUM LOCK led stay on - forgot what I did to resolve it).
I have 6 optical mice and all of their LED's shut off when the system is off.
All the optical mice of my friend's systems (MS and Logitech) turn off as well.
Sorry, don't know what you can do to fix it.
Fokks suggested the wake-on settings in BIOS. Try that.
