IGBT
- Jul 16, 2001
- 17,958
- 138
- 106
Originally posted by: Netopia
One the dozen or so machines that I've had to work on that had IE7 installed (through auto updates), IE7 was the cause of the problems I was called for. Network security locked up so tight that things wouldn't work, programs not functioning, general slowness. In each case, when I rolled back (via System Restore) to a pre IE7 environment, the machines were fine. I then manually went in and disabled the update for IE7 on those machines.
I'm holding off for a while too... and then I'm going to test it on an unimportant machine!
Joe
..I went back to IE-6. The AT+T tools program I downloaded is causing the problem. They have a work around hack but since it's a pre IE-7 release there may be other undiscovered issues.
