I've just clean installed winME on my newly built computer and I've discovered the infamous yellow ? next to Other devices and another next to its branch [PCI Mass Storage Controller]. So I flip over to System Properties under performance and in the Details box it reads as follows:
Compatibility-mode paging reduces overall system performance
Drive C is using MS-DOS compatibility mode file system
Drive D is using MS-DOS compatibility mode file system
What do you think I've done wrong or is it because I used a 98se
boot disk to fdisk,format and load the OS..
Is there any thing that I might have changed in the BIOS setting when I was setting up that is causing the concern.. Thanks for any suggestion you might have in advance...
