- Jan 23, 2002
- 2,206
- 12
- 81
The data are found in multiple columns, however, each row contains only one data entry. I need to consolidate them to one column only (A1 to A11, for example).
Excel Chart
For instance guys:
I have some numbers in A1, B2, C3, C4 and C5.
As you can see, numbers can be in the same COLUMN, but not the same ROW. I'm basically trying to shift the numbers left.
A1 = A1
B2 = A2
C3 = A3
C4 = A4
C5 = A5
How the hell do I do this? Is there a function for this?
Your first thread on this was moved to Software for Windows for a reason.
Moderator allisolm
Excel Chart
For instance guys:
A1 = A1
B2 = A2
C3 = A3
C4 = A4
C5 = A5
Moderator allisolm
