MPEG2 to divx conversion
Demon-Xanth
20,551
I'm trying to convert something that I captured from my TV tuner card in MPEG2 (that's the only format it can do, and it does it in hardware) to a divx file to save space. Currently the 70 minute file is 2.2GB. That isn't going to fit on a CD.
The basic format is a single .mpg file that is 640x480 w/ the audio in MP3 sampled at 32kHz (just one file mind you)
So far all the programs I have tried have:
1: Expected an ac3 audio and vob video file that was ripped from a DVD
2: crashed 100% of the time (flask 0.594, 0.6 when I choose a codec)
3: generated massive audiosync problems (vidomi)
4: generated files larger than the original, that wouldn't play smooth on a 1Ghz Athlon (flask 0.6 when I try uncompressed audio)
Again note: the video is not coming ripped from a DVD in any way.
NicColt
4,362
your tuner card does hardware..... I don't think so.
does it absolutely have to play from a cd.... with cheap HD space I winRAR files that are 2GB onto a cpl of cd's and uncompress them to HD when need be, that way I still have high quality and one single file.
If I need compression, as for MPEG2.... I use either Vegas or Video Factory to render them to Windows Media Video v8 which is much better than divx for compression/quality. I have them preset in my settings as to how much time/quality/file size will fit on a normal cdr or rw. You just have to test this yourself.
Demon-Xanth
20,551
<< >I captured from my TV tuner card in MPEG2 (that's the only format it can do, and it does it in hardware)
It does, and my CPU usage shows it. Both the Haupagge WinTV-PVR and the Creative Labs Digital VCR do hardware MPEG2 encoding. (I have the latter)
<< >That isn't going to fit on a CD.
I plan on saving this to a CD for archives as well as sending this off to family. The target size is about 300-400MB (medium quality divx)
rbV5
12,632
I've used Gordian Knot (get it here ) with great success. I use it to compress my Mpeg-2 captures from my AIW to Divx. LMK if you need help with the workflow and I'll hook you up with the method I use.
NicColt
4,362
I stan corrected, they do say "onboard hardware MPEG-2 recording engine" I didn't know that anyone had a Hardware MPEG2 card yet. and for $99 how can that be ???
I still think that WMV has much better compression and video quality than any divx.
