- Nov 26, 2007
- 890
- 0
- 0
I am not an audio aficionado, so I can't describe it any better, but some of the mp3s I download sound empty and bland. While if I watch say a Music video it seems to feel Full even though the track is only 128kbps mpga.
Originally posted by: BassBomb
It all depends on the rip and the source
Sometimes the dB are too low on a rip and can make the entire thing more "normalized" and less impressive.
And sometimes dB are too high and make everything overbassy
Originally posted by: Calculator83
So what can I do to make it ""full"".
Does that Xfi card thing do it? I have an old 2zs right now.
Originally posted by: Rubycon
Compression in MP3 encoding and compression (RMS normalization - commonly used in broadcasting to make advertisements as loud as possible without splattering) are completely different things. MP3 compression will NOT change dynamic range.
The only way to compare the two is have the CD and MP3 and listen to each. (ASSuming the MP3 you have was encoded from the same source as the CD)
The crystalizer feature on x-fi cards is a combination of an upward expander (to increase dynamic range) and a dynamic equalizer with bands in the lower ranges and higher frequencies. It distorts the output and should be used very carefully and very conservatively. At the maximum setting it can overload the sound card's output producing a distorted waveform that can damage speakers if the volume level is set too high (even if the amplifier does not clip!).
I gotta find ways to stealz directly from the studios then. mm
Many box sets are straight from the masters. If you really want sound quality then get a record player.
Better than the record player but not for the faint of heart I mean wallet.
