have a motherboard pulled from a proprietary system, onboard video and sound and its flat, all connectors in a row.. so it wouldnt fit a standard AT case, but I have the perfect metal enclosure i found in the garbage, its 1" high (will dremel air hole for hs/fan)
it supports up to p133 and i wont have any cards on it since its onboard vid and sb16.. but when I slide the board into the "sleeve" case, there is only room next to it for an AT power supply that is 2.5" wide and 1" tall.
so where could i find such a mini power supply ?
