Mozilla is totally going haywire... help
Vich
2,849
So all of a sudden, my theme is gone, all my bookmarks and my extensions. They pop up to be configured but they dont work. This happened while my internet was out, could it be a coincidence?
I dont get how everything could have just been set to default?
stndn
1,886
is it Mozilla as in Mozilla suite, or Mozilla firefox?
if it's the later, it seems to be a common problems which unfortunately happens to quite a few people.
either way, check the obvious:
c:\documents and settings\[your windows username]\application data\mozilla (or firefox, depending on which one)\profiles\ and see if your profile is there
also, check your computer for virus, spyware, etc .. all the works
Vich
2,849
Yeah its mozilla firefox.
No virus spyware or anything, it just happened!
I never had a profile for mozilla how do i make one?
igowerf
7,697
You don't. He showed you how to get to your Firefox profile.
CTho9305
9,214
If you use Firefox, you have one.
Make a copy of the shortcut you use to launch firefox. Then:
(19:46:58) Tristor: you right click on the shortcut, select properties, and in the target box, you add -P after the quote
(19:47:00) Tristor: with a space before the -
