moving sound card to different pci slot
MeNiS
11
hi, do i need to reinstall the driver when i move my sb audigy card to a different pci slot??....after i plug it into the new slot, xp showed that 'new hardware found'. when i checked the properties, the driver is listed...so am i good to go? thanks
bolomite
3,276
you should be all set as long as you don't have an ! in control panel/device manager
RustyNale
2,220
Welcome to AnandTech, MeNiS.
If you're not experiencing an sound issues, you're fine.
