Originally posted by: Kensai
If you move it with a full loop, you better be careful, make sure all your connections are tight.
Still, if it leaks, it shouldn't damage the hardware as long as you don't power it up while it's still wet.
??? couldnt the NaCl deposits from the evaporated water on any of the ICs be conductive and total the hardware? or is soadium only conductive when its dissicoated in water?
That only applies to impure water. Assuming he's using filtered distilled H2O, he should be okay.![]()
Originally posted by: Safeway
True, Mrvile ... Except that I have yet to put in a drain valve :laugh:
That would be alot easier. I use 90% distilled water, 10% plain antifreeze. So I'd need to pour off some antifreeze into a water bottle![]()
Antifreeze...yuk. I'd like to use it (especially for the anticorrosive properties) but my parents will not stand antifreeze anywhere in the house
I don't have a drain valve myself, but I find it easy enough just to pull the tube from the res, pull it down as low as it goes and draining it that way.
True that. Anti-freeze is a definate yuck. I used it for the anticorrosive properties you mentioned, and to soften the water a bit. It helped keep bubbles off the blocks and res. I also heard and read that it will help keep a loop algae-free.
I actually read that, but the 90/10 was suggested by many HardForum memberes (not noobs either, 'lifers' if you will)
Well what I'm saying is that you should know exactly what goes into your loop.
For example, if you do 90/10 with Prestone Antifreeze, you get about 9pH, ethylene glycol, diethylene glycol, proprietary corrosion inhibitor, is toxic to humans and animals, works as a moderate biocide.
