moving a Raid 1 drive...help
nemo99
Hi,
I recently had a drive failure of a Raid 1 drive.
I also finished building a new computer system last night. Can I hook the one good Raid 1 drive (not in RAID) to the new system and retain the data?
This is a storage drive, not my boot drive. I just need to get the data off it to my new computer.
Thank you in advance for your help.
RebateMonger
11,586
It might depend on the RAID controller used, but I've done this with a simple HighPoint RocketRAID IDE controller.
Paperdoc
2,500
375
IF your older computer that contains the RAID1 drive is still working, there's a very straightforward and secure procedure. Read your RAID manual for details. The software included with your RAID control system (even if it's a built-in RAID system included in the mobo chipset) has tools for creating the RIAD1 array from 2 disks, of course - you've done that. But it also has tools for UN-creating that array; that is, to split the RAID1 array into two separate independent disks which (if you were starting from a trouble-free pair) would each contain an exact copy of the other. Now, in your case, you have a degraded RAID1 array because 1 disk failed, but it is still operating under RAID control. Look for the methods to be used in this case - a broken array with only one disk working - then undo the RAID array back to independent non-RAID disks. Except, of course, you will have only one functioning disk. But at that point it is no longer a RAID disk - it is just a plain regular hard drive full of data that any machine can use. THAT is what you move to your new machine for copying its contents.
