Heya. I am going to be soon creating a movie and after I made my last one almost 2 years ago I have been pondering which movie editor that I should use.
Which Movie Maker I should use. (I have all of these) Some facts:
1. Windows Movie Maker-
---Good: Easy to pick up and go, small file sizes when exporting the movie
---Bad: Not enough effects, cannot create effects, not enough transitions, not exactly "Grade A" quality when exported.
2. Adobe Premiere Pro
---Good: Excellent Effects, Transitions, Allows you to make your own effects, precise timing.
---Bad: No Matter how hard I try, the file size is outragous, after months of attempting everything, the only way I can get the file down is to DIRECTLY talk to someone via IM and figure out how to fix this. The preview window lags, its kinda complicated to make effects, well very complicated.
3. Sony Vegas 5.0a
---Good: Stable Preview Window, small and good quality file sizes.
---Bad: I have no idea how to edit, never touched it since I havn't made a movie. I don't know if you can make effects.
Criteria: The movie will be 30 Minutes long, I would like it to be full screen but I can deal with a smaller screen size to save space. I do not want it to exceed 200MB.
I think I will begin making my movie immediatly after I buy an additional hardrive. If anyone has read this and has a suggestion, or comment, I'M HERE MAN!!
3. Sony Vegas 5.0a
