Moved to Cases and Cooling
Status
Not open for further replies.
Herkulese
This was posted in the wrong forum, and it was suggested that it be moved to Cases and Cooling.
My bad..................
Moved from GH, will need C&C mod to merge.
mfenn
General Hardware Moderator
Rosewill cases: nice designs, horrible quality control.
Ordered two Blackhawk cases, the headphone ports are recessed too much, such that plugging in a headset, it pops out, and you lose stereo audio.
Ordered two Redbone cases, one had the rear corner bent, one had a loose power switch that fell out and got lost.
The third one (the Thermaltake case) doesn't have a mesh front. It has a solid plastic door, behind which is access to the front fans and the 5.25" drive bays.
Your top two links go to the same case on Newegg.
This is not the way to move a thread... what you want to do is inform a mod so he can actually MOVE the thread, rather than create a duplicate thread which is bad practice. You could ask a mod to merge the posts from this thread into the one in Cases and Cooling.
How to I contact a moderater, or are you one?
Just decided to close the thread...
Please use this one for a continuation
http://forums.anandtech.com/showthread.php?t=2375839
Cases and Cooling Moderator Aigo
Status
