I've been unable to find concrete information regarding mouse DPI.
I understand that mouse DPI is dots per inch, and that if I have a mouse that's 1000 dpi and I move it one inch physically, the pointer on screen should move 1000 dots per inch on the monitor.
What I don't understand is this. I've read conflicting things about high DPI. If it is literally just dots per inch, then I don't see how it helps a lot to go higher than say, at most, 2000 DPI. The reason being I simply can't control the mouse pointer going that fast, if the windows pointer speed is at the default 6th notch.
Now, I can set my mouse to 4000 DPI and put the windows pointer speed at the 3rd notch and it'll feel right. However I don't see what the difference is between that and the 6th notch at say, 1200 DPI. They feel similar.
I know this could start all kinds of arguments.
That's really not what I'm looking for here. What I want is some concrete info on a few things that justify high DPI.
I've read that anything but the 6th notch uses software interpolation, which means the mouse DPI is basically being altered via the OS. To me that implies that the mouse DPI isn't such an important thing anymore (high DPI anyway).
I'm know I'm getting really technical about this, but I've been thinking about it a while and I really want to know what's right/wrong if anyone knows.
I contacted Razer about it and they said to ignore the windows point speed settings and that the DPI adjustments override that. To a point I see what they mean, however it doesn't totally override it. I can move the pointer speed with my mouse set at a constant DPI and it will change the mouse speed. So to me, it isn't really overridden. I assume they mean leave the default setting in Windows, 6th notch.
Anyone have some insight on this?
If I missed a thread in search that answers all my questions let me know.
