I have a MS Intellimouse with Intellieye USB 1.0.
When I press once - and I have confirmed using the mouse diagnostic program I am only pressing once - windows (98) responds as if I've double-clicked. This means if I try to select a file, grabbing it to move to a different directory, the file opens in its associated program, etc. This occurs across all tested applications.
Nothing jumps out as strange in the mouse control panel. The left button is still set to click, click lock is off, double-click speed is medium. Are there settings that can get around this problem? Would a driver reinstall help? or does this appear to be a hardware issue?
thanks,
sathyan
thanks,
sathyan
