Mounting fans on hyper 212 evo w/o clips?
popop
125
Anyone done this? I am short one clip now and want to mount a second fan. Best way to do this?
dma0991
2,723
Use a string, preferably nylon or fishing line to loop it around the gap where the brackets latch on to. It won't look pretty but it'll work. Don't use rubber bands or anything with adhesive. Over time, the heat will create a mess as they adhere to the surface.
dawp
11,347
2,709
I used wire from a cat5 cable I had laying around to fasten 2 fans to a rad with stripped screw holes.
Ketchup
14,558
248
I'm sure Coolermaster can supply these for you for a nominal, or no fee.
I have had good luck with them on this. Depending on the item, I have seen them ship me stuff for free, and for a small fee. I would go with this. Shipping times depend on where they are shipping it from.
