<< Maybe I should rephrase this, Instead of entirely mounting the fan inside or outside of the case, you mount it in the center. So half of the fan is on the inside and half is on the outside.
I just need to find a way to securely do this. >>
That crossed my mind the first time, but then I thought to myself, "Self, that makes no freaking sense", and I dismissed the idea. If you hold a can of soda from the top rim, the middle, or the bottom rim, you're still holding the soda in virtually the same way, right? Same with the fan, except your case is gonna look sofa king we tall did with fans sticking halfway out...
